Hi Lo Switch
89 v6
I've been running without hi beams now for awhile. It can be a total pain and for safety I should fix this.
Here's the deal. If I pull back on the signal arm (as you would to flash an oncoming vehicle) the hi beams will work. However if you push the arm forward as you would to turn the hi beams on--no hi beams...
Seems like it's the switch to me as the actual lights do produce the hi beam.
Does anyone know if this is a simple swap, if this is a part I have to get from the dealer or is their a better (cheaper) source, and lastly does it sound like I'm on the right track here?
Thanks for any input....
Yep I'd go with you on the switch, Same thing happened on my friends accord no hi-beams or turn signals.
