HID retro help!
Eastcoastrunner
hi! i found all my retrokit stuff to add projectors/HID to my runner. Unfortunately, i am not an elect. guru and would like to see if anyone can help with the harness?
here is a pic. The tagged wire says '2nd high beam' in it...
i believe this is a 9006 converting harness....the orange/black clips go to the ballasts, and i assume the two top 'ring' ended ones go to pos/neg battery terminal.
My question is, which is which, and where does the high beam tagged (green tape) go?
would should have:
positive wire to battery - should be long lead with fuse
neg to ground - short lead from relay
wire to each balast - orange and black
wire to one low beam plug
and wire to high beam plug
do you have bi-xenon lights? what year do you have, current projector lights or reflector?
most peope just run a single xenon setup with the 4r and just replace low beam.
hey, thanks for the quick response.
I have an 03 runner, and am going to retro fit tsx projectors for low beam xenon only. the yellow box is a fuse, and there is a black relay there too. So that clears up everything but the one that says '2nd high beam' green tag in the pic.
It has a |_| three pronged end.
u should have some pigtails if u use the aftermarket ballast, just plug it in the factory wires, and get the harness later, other wise to make that h4 harness u have to work, u have to put the pin that is mark L to the pos of the stock plug, and one of the neg to neg on stock plug, shouldnt take alot of work to figure out , but use a dmm to figure out the wires on the harness.
Relay Diagrams - Weak Positive Output to High Current Positive Output
use that diagram and trace the wires on the relay and the h4 plug. u dont need to connect the wire that says high.
