HID Wiring
hulk311
I need some help wiring an HID kit and need to know which wires go well. Basically, I know where everything plugs into except for the wires from the ballast (in the plastic box) and the stock wires that plugged into the halogen bulb. Here are some photos:
DSC_0407.jpg~original
DSC_0406.jpg~original
DSC_0405.jpg~original
DSC_0404.jpg~original
DSC_0402.jpg~original
DSC_0401.jpg~original
you missing a wiring harness with relay. That red knob with pig-tail plugs to HID bulb -> into ballast -> then wiring harness to connect to your stock sockets.
Are you doing a retrofit?
Careful with those ballasts. They are not designed to work in temperatures over 80 Degrees celsius.
Steve
I installed murano projectors with this wiring kit H4 9003 Bixenon Relay Wiring Harness HID and Retrofit and the low beams work just fine but the high beams are not working at all. Furthermore, when I switch the high beams on in the truck the high beams icon doesn't even light up on the dashboard. What is wrong? I was under the impression the murano projectors were bixenon?
