HID's installed- VSC, ABS, Brake Indicators are on!
jaxbusa
Hi guys, I searched the forums and couldn't find a definitive answer or if anyone has had this problem. I have the H11 HID conversion kit for my 06' SE V8. When the lights are turned on, they flash bright and them dim. Then they cause the VSC, ABS, Brakes indicator lights come one. When the headlight switch is off, these indicator lights do not come on. The HID also cause my amber side marker lights to flicker. Any ideas or help?
I'd try another set preferably another seller. I've had HID Lowbeam and Fogs for years never had any issues. The initial brightness then dimming is completely normal but all the other issues i've never seen.
I am going back to my guy tomorrow. He has installed many of these kits, one on a FJ and no issues. I am hoping maybe a ballast is bad and we can replace. Good to know about the brightening part though. My hubby was worried that was not supposed to happen.
:redbrick:
It was a plug and play kit that my friend installed. He is a professional car audio/custom build shop for all things auto manager and has installed these exact kits in FJ Cruisers and other makes. I went back today and he troubleshot every thing he could think off. He even used the "problem eliminator" plug ins! He finally brought out a relay that has a separate fuse and wired that into the truck and everything is now fine. He said the ballasts and wires themselves were just not drawing enough and causing my parking lights to flicker. His best guess is that the VSC/ABS/Brake light indicators were tripped up by the new hardware. So we shall see.
