I installed HIDs in my 3rd gen before I sold it but thought I would go the easy route with my 4th gen pre-2006 headlights and try High Intensity Infrared (HIR) bulbs. Eventually I will probably do a proper HID projector retrofit.
Not much talk in the forums on HIR bulbs for a pretty long time. I assume that this is given the much lower cost of going the HID route these days. HIR bulbs are comparable in cost to Silverstars (and similar) with better light output. This BMW thread has a decent picture of the difference (second one down).
The biggest difference between HID and HIR (besides light output) is that the HIR install requires no real installation. Minor modification to the housing on the bulb is all that is required. Using a bench grinder it took me about 10 seconds per bulb.
In Summary, it was the easiest mod I’ve done to date with decent (but not HID bright) results. Definitely worth it if you don’t want to go the HID route and worry about the reliability of Silverstar bulbs. HIR bulbs also seem to be brighter and the newer Phillips bulbs are 25% brighter and last 40% longer than the Toshiba bulbs.
I purchased the bulbs from Candlepower. The HIR bulbs were cheaper here than on eBay and they are running a summer special right now where you can get all four bulbs for $100.
Here are the bulbs as packed and shipped.
