high pich squeal?
Rc4r
4runner makes high pitch squeal when giving gas ~ above 2000rpms. I thought it was timing belt.. so that was replaced a week ago. Still having this isue, could it be a u joint possibly?
Have you checked your accessory belts? Sounds like a belt issue, u-joints usually aren't that loud and you would definitely feel a vibration if it was that loud.
Does it squeal when not moving?? If so, obviously NOT a u-joint. Timing belts are cogged and never squeal, ever. As said above, either loose accessory belt or one or more is due for a change. You can spray water on the belt pulleys with an old Windex or similar bottle, the noise should stop briefly if you hit the right spot.
The other possibility is a problem in a driven item, P/S pump, alt., A/C compressor, fake water pump, or idler. To examine this, take one belt off at a time until you find the culprit. Instructions on belt removal in Documentation sticky at top of forum.
