⚡ XenonDepot Super Sale!
It's Friday again, and you know what that means - time for some more pictures showing off some brighter lights.
What I have for you today are some great images of Interior LED Replacement Bulbs sprucing up a Toyota 4Runner. Seeing is believing, and you can definitely see the difference that these Xtreme LED 194/T10 LED Bulbs and
Xtreme LED 3022 30mm Festoon LED Bulbs make.
Both of these styles feature a warm 5000K colour temperature, brighter-than-stock lighting, and a sleek ceramic design.
Big thanks go out to Instagram user @lifestyleoverland for sharing these images with us.
Check out XenonDepot.com for all your Forward, Rear, and Interior lighting needs.
~Robert
#TACOTuesday - time for some great pictures provided by TacomaWorld forum user @RobP62!
Vehicle: Toyota Tacoma
Featuring: Xtreme PRO H11 LED Headlight Kit (installed in both Low and High Beams, because newer Tacomas use equivalent bulbs for both applications)
From the front:
And here's a road shot of just the Low Beams in action:
Our high-quality LED Headlight Kits and LED Fog Light Kits feature grouped diodes that closely replicate the OEM beam pattern, passive cooling in the form of flexible aluminum fin heat sinks, and a 'clockable' design, which lets you adjust the final positioning of the diodes when your bulb is locked into place. Since the LEDs are only shining out light from two sides (rather than a 360 degree light pattern, like the halogens they are replacing), it can be very important to make sure your diodes are facing where they need to in order to best disperse the light. We find the best results come from having the diodes out side-to-side (like 3 and 9 on a clock face), and you may need to adjust the positioning to make this happen. Not all LED Kits have this feature - look for adjustable ones if you are in the market for an LED upgrade.
Check out XenonDepot.com for all your Automotive lighting needs.
~Robert
Hey everybody!
One of my favourite lighting combinations is the projector Low Beam housing of a 2018 Toyota 4Runner and one of our Xtreme H11 HID Kits.
What's your favourite lighting combination?
~Robert
charlesz
