Highest Mileage 4th Gen?
I've seen a few in the AutoTrader with over 100K for sure since I've been trying to get a good idea for what to sell mine for.
All I know is I'm sure I win with the lowest mileage. I have a 2003 with 23,045 miles on it :D
Hi Miles 4th Gen
I have an 04 2wd (purchased 12/03) that has 100,100 miles right now...still getting 20MPG hwy.
These are low, my friend had a 230k miles 91 4runner which was stolen in 2001.
My cousin has an 05 4Runner - 55k.
It's so reassuring seeing all the high mileage ones out there, doing just fine. Mine just broke 58k and I was feeling bad, it's a 2003!
98,000- no problems (knock on wood!)
03 limited v8
123,964 as of today.
no problems. runs just as good as new. although the power steering pump seems a little noisier than it used to, but it may be low on fluid, it hasn't worried me enough to check it.
secretagent, I had a noise after I replaced my serpentine belt , that I thought was one of the idler pulleys, $50- later still had the noise so I replaced the tensioner pulley assembly $140- later still had the noise, It's the power steering pump, toyota wants like $500- napa and advance are about $130-
thanks for the heads up! i'll have to keep an eye on it then. it still works perfectly, just sounds like a bearing going out. probably the same exact problem you had.
seltzernator
