First post, although avid lurker. I've read the achives extensively but still have questions. I have a 2005 Sport 4x4 V6 with a hitch receiver that is welded (not bolted) to the crossmember, this is the way it came from the factory.
I was rearended and the hitch now has a 30 degree downturn towards the ground. It is obvious that the cross member is twisted because the paint on the cross member/frame weld has chipped off. My plan was to have a certified welder replace the cross member. From here I have questions, should I replace the welded on hitch to the cross member, or go with a Curt or similar replacement. I do like the idea of having it bolt to the cross member as well as the frame rails.
I pull a 5300# tandem axle trailer(boat/trailer/gas) with surge brakes. I'm not exactly sure what is the tounge weight.
