Hitch storage box/carrier
Mtneer001
I'm not exactly sure what the correct name is, but I'm looking for a storage box carrier that I can put on my trailer hitch for long trips.
I want something that has a hard plastic cover on it.
I saw where Thule has one, but it was almost $500.
Is there anything out there just as good for a little less price?
Just wondering.
I don't know about a complete box set-up, but there are many hitch haulers that are just the metal rack with short side rails for around $200 or so--then you could add one of those heavy-duty plastic boxes to that for maybe another $100 (or less). This way you could take the box off and use just the rack for odd shaped items, etc.. Just an idea.
Just get a Hitch Haul and some plastic totes. I use my hitch carrier to carry saws, lumber, concrete, firewood, a lawnmower, fuel tanks, gas cans, transporting a scooter, hauling a bushel of crabs and oysters... It comes in handy. I think it was about $70.
If you put one on also consider that blocking your license plate can get you a ticket in many states also the straight back exhaust can create enough heat to melt plastic
I have this "pro Series" one 24x60 Railed Cargo Carrier for 2" Trailer Hitches Pro Series Hitch Cargo Carrier 63153
It is just a basket but you can buy various size tubs or trunks to sit in it. I did flip a tarp over the edge one time while i was getting yard trash off of it and melted a hole in the tart from the exhaust. So keep that heat in mind if your exhaust still exits the back. I have thought about making some kind of heat shield but haven't yet. With a locking hitch pin its very stable.
Thanks all for the replies. Its crazy how expensive the cargo carriers from thule are. i would have preferred something that will lock since i travel a lot.
This. Harbor Freight has 'em for dirt cheap, and you just bungie a couple ActionPackers to it. You can padlock them and run a bike cable to the hitch to keep them secure on road trips.
Or, pay through the nose for something with a name brand on it...
I've used the Harbor Freight carrier for a trip to Denver from Ohio and on shorter trips around Ohio. It's light and made from Aluminum. I wrapped normal luggage with a blue, plastic tarp to make it water resistant. One thing to be aware is the effect of the bins or luggage rubbing against the metal over long trips. It can cause damage if you don't use something in between like a towell or pipe insulation. Make sure that you tie it down securely.
Harbor Freight currently has the 500 lb. cargo carrier on sale for $39.99 with a coupon! It's the black steel one, not aluminum. Coupon was in a sale flyer I got in the mail.
I bought a trailer hitch carrier last month and loved it, however I had some old web type elastic tie downs that have dryed out and stretched, I use tie down straps for my coolers and such but I have two soft bags that I put on either side, just wondering what you guys use to secure your soft bags to the tail hitch?
I use ratchet straps for most everything. I had a bungee cord break on me and gave me a bruised cheek so Ive had enough of those. I can laugh about it now but at the time it sucked.
Yeah I don't like using the ratchet straps as you don't really know how much pressure your putting on the object being tied down, I guess I'll just stick to the other tie downs I have.
i think the Thule option is expensive but the Terrapin is a great product. I got mine in 07 and it's still works great. It has a life time warranty and i have replaced it twice, once while off roading a friend hit me from behind and it didn't lose any of it's contents locked inside but it was pretty messed up. Second time some one tried, and failed to pry it open when locked at a truck stop. Both times rei replaced it free, plus they always have 20% off on thule products. The Terrapin is the swing out model over the swing down model currently on Thule's site. I just didn't want to swing it back up fully loaded. A lot of the cheaper ones i found had no options built in, where cheaply made, and squeaked and rattled a lot. Terrpain has lighted plate mount, box lock, hitch lock w internal mechanism that takes away ALL vibration/sqeaks, same key both locks, tail lights, internal drain (makes a great huge beer cooler). I use it a lot for scuba, after dives i pack my gear into it, put some cleaner in w gear, back up into the lake and fully submerge the lower half in the water and drive home, by the time i get there my gear is clean and mostly dry, lights never short, box never rusts, wiring an internal light was simple even for non-DIY me, top of box is visible through rearview mirror and those cool mirrors in the rear headliner on my 05 w/o obstructing my view, mpg never changes when it's attached, and its light enough to easily remove all by myself, plus everywhere I go when ever outdoorsy people see it they seem to have to ask about it!
Stock exhaust can cause issues
I tried a Hitch Haul unit combined with this heavy toolbox from Lowe's . Even with very little sitting still in traffic, it melted a hole in the bottom of the box. I didn't think I'd have a problem since it was mostly interstate driving and the box was heavy duty plastic. Any ideas on what to build a heat shield out of....or if there are any bolt on exhaust tips that would point the heat away from the back? I've tried several from Advance/Autozone, but none are big enough to fit over the stock exhaust on an '08 with a V8.
