Holding hatch open (no supports, no roof rack)
Deej101
Doing a job alone, so no helper to hold the hatch up.
What is the best way to get the hatch to stay fully open?
Run a rachet strap from the front end over the top? How to attach to hatch? Loop around?
Similar question for doors, actually. My car is usually parked on a slight incline, so keeping the doors open while working is a challenge. Any easy solution?
Creative input appreciated!
ladder to hold up the hatch, you could wedge a block of wood in there, get a stick to prop it up, there's infinite possibilities, just gotta work with what you have
I mostly use a long piece of wood as a prop for the door. Wood block would work just not sure if it bend or dent anything as there is some weight to these hatches. I just change one at time. As don't do what I did once. Disconnect the lift supports and take the hinges loose by yourself. That can be a bad situation very quickly. :/
Visegrips clamped on inner lift tube against outside tube - EZ and not in your way.
Sounds good. Now, how about if there are no struts? Because I already removed both from a junkyard rig but now wamt to go back and get the hatch license frame/garnish?
Too late! Already did that.
ghengiskhan
