Philbert
Hello again guys,
Like many 4runner owners, I've been victim to the "sag" of the rear end. While it makes my truck look crippled, my recent concern is the comfort and/or wear on the chassis.
When I go over small speed bumps in parking lots, the back really shimmies and it feels like I'm carrying a ton of bricks in the back (when the truck is empty) - the rear end just slams and bangs a LOT.
I finally got down and checked out the back - looks like the gap between the bump stops is really tiny - see photos below - less than 2 inches is my guess.
I had a Pro Comp 4 inch lift kit installed about 12,000 miles ago and they used blocks in the back - not new springs - to lief thte back.
My questions are:
1) Is this small gap dangerous to ride around with till I replace the springs later this year (assuming the bump stops are making contact when I go over these speed bumps and other bumps...)?
2) What's a good set of springs I can replace these with (I have a friend who has the tools and know how to install)?
3) When I replace the springs with new 4" or 5" ones, do I keep the blocks in from the 4" lift kit on there, or will that create a ridiculous lift in the rear?
4) Is it bad to have a slightly higher rear than front?
Here are some photos of the gap (or lack of) right now:
(about 2 inch gap...maybe):
View from behind - driver's side rear:
Rear driver's side leaf spring - see how flat it looks??
Again - see the utter flatness here?
Any insight from those who've dealt with this would be wonderful
I plan to replace these in the fall and want to ensure I can make it till then - I likely will drive less than 5,000 miles between then and now - this is my 3rd car.
My questions are:
