Horn not working....
el_jefe
I took the horn off and wired it directly the battery and it works fine. I am missing the manual and the fuse box diagram is worn off the cover. Do you know what fuses/relays are for the horn?
Also has anyone had a problem with the horn switch in the steering wheel? If so does the air bag cover just pull off?
well i just checked the pdf i have for the horn (2000 model year), the fuse is listed as horn/hazard, so if the hazard lights work, its probably not the fuse.
Wiring is super simple, no external relay or anything. Green w/ red enters the body ECU, looking for a negative trigger from the switch, black leaves the body ecu w/ a +12v output going directly to the horn.
not positive if other years are the same color wise, but you could test the wiring into and out of the body ECU rather easily and see where the problem is.
