03L4RUNNER
Hi everyone,
Ive had my 4runner since 2006, its an 03 with 113,000 on it and here is a list of parts Ive replaced so far, (just in the front suspension)
In total 4 front wheel bearings
Both CV axles
Slotted rotors in front
Front sway bar bushings
New outer tie rods
So my question is why in the world does my front end feel so bad? I have OME full lift and Im running BFG KM2's 255/80R17.
I get a death wobble and vibrations around 45mph to 60 mph, I just had it aligned 2 weeks ago at NTB and they told me it was the best they could do since Im out of possible caster adjustment. And they "balanced my wheels" using a lot of weight, ( Ive read up that the new KM2's are a B to balance)
The only solution left to try is a shop that actually has a wheel balancing adapter that will fit 6x5.5 Toyota wheels to get a true lug centric balance instead of the common hub centric.
Should I take it to some other place to get it aligned and balanced?
What are your opinions on my problem?
Thanks in advance
Both CV axles
New outer tie rods
Thanks in advance
