JacobDylan
Hey Everybody. I've had my 4runner for about 2 years. It is a 1998 Limited. For the past year is has started making an annoying squeakign noise. The noise is loud enough so you hear it when you're inside of the car, and when you're outside of the car it sounds horrible. Here's the tricky part: Whenever you touch the has pedal, or try to brake the squeaking noise will stop. The noise is only there when you are "coasting" and do not have a lot of pressure on the gas or brakes. Does anyone know what could be doing this? I've crawled under the car numerous times, and i cannot figure it out. Help!
