E30RUNNER
I got my codes ran and the two following DTC Codes came up reading circuit malfunction:
P0100
MAF or VAF
P0110
IAT Sensor
The reason I went there is because my mpg still hasn't improved after all the work I've done to it. I am getting on average of 14 mpg and that is doing about 60% highway /40% city
Should I replace both of these? Would I see a major improvement in my mpg if I did?
BTW here is the work I've done so far:
-Coolant Flush
-Front & rear differential Flush
-Replace the PCV valve
-Cleaned the throttle body and the MAF sensor with air intake cleaner and MAF cleaner
-Changed the air, oil, and fuel filters
-Brake fluid flush
-Used the BG44K Emission cleaner set
-Timing Belt/ Water Pump
-Crank/Cam Shaft Seals
-Replaced Spark Plugs/Wires (NGK)
-Replaced the three belts I'm not sure what they all go to
P0100
MAF or VAF
P0110
IAT Sensor
-Coolant Flush
-Brake fluid flush
