how can i turn off my chirp?
4rnr4me
on my keyless entry? its sooooooo annoying!
I have the 99 4runner 2wd sr5, i dont know my keyless entry's model, but maybe u guys do?
I found instructions for lowering the volume...BUT I gotta try it AND I dont know if it turns OFF the sound or just lowers it...ima go try it in a few
On some aftermarket alarms you can hold down the lock and unlock buttons and it goes to silent mode. I'm 8hrs from home right now or I'd try it.
1. open any door
2. hold down the unlock button...and dont let go...it will beep normally, and then it will beep again twice...
3. then push "window down" for down or "lock" for up and adjust your sound...WHILE HOLDING DOWN UNLOCK THE WHOLE TIME!
not much of a diff tho...ima try a few more things
Actually that is a lot better than what mine was set at. Don't get me wrong, no sound at all would be great, but I will settle for this.
Evan
I am GOING TO FIND a way to turn the sound off...i will get back to you on it when i do...i have NEVER taken on a mechanical or tech problem that i couldnt figure out!
Yeap. I'm trying to figure out a way to turn off the chirp completely still...ill get back to you guys...
Wow.
It was SO simple.
Disconnect the chirper from its electrical connector.
Done.
The lock/unlock still works and flashes, but no annoying chirp. Its under the hood to the far left.
LOL it was sooooo easy, if you can't find it on your own I will take pics soon. Not tomorrow as I am going to be busy, but soon.
hey rockslide i just got done with ur instructions..Should i put somthing over the buzzer because im just gonna leave it in there?
I would.
Cover the exposed connections on both it and the plug wire w/ electrical tape. Then to make sure the elect tape does not come off due to heat, take a zip tie to each connector and place the zip tie around each piece that has tape on it. Should be good to go then. :D
