How do I get the TPMS light to turn off?
thefatcat
My TPMS light came on my '05 SR5 so I added air to the tires at 50psi each, tire says max of 52 psi.
Cannot get the TPMS light to turn off on my dash?
I'm assuming there is a way to get this light to turn off...
50psi?? that's a lot, you only need to fill 52 at max if you're carrying full load. I suggest you lower hte ps1 to aroudn 34, and check each tire including spare. once the tire pressure is aourndt he same park the tpms light will automatically shut off. Unless you have a model with a tpms manual shut off button.
You have to drive for a while before they register the change. Can't remember how many miles it took mine, but is was a few anyway.
Good Luck
