How does TURBO work and what is the $$?
TY4Runnin92
I'm looking around for performance parts that I may purchase and install in the future. Can anyone explain to me:
-What they do to the engine?
-How I may benefit from a turbo system?
-What is the price range?
-Do they make them for a 1992 3L V6 4x4?
*I'm hungry for power!* :yummie: :spam:
A turbo charger uses exhaust gas to turn an impeller. The other side of the impeller forces air into the intake at a higher pressure than would normally be possible. The higher air/fuel mixture produces more HP.
$2-3000
Oh ok, thanks. I wasn't expecting that high of price, but I guess horsepower doesn't come cheap :)
Maybe I'll get one for when I own a more expensive automobile.
while I don't have alot of turbo info for you - I do have some reasonably bad news. HP on the 3.0 is NOT cheap. As far as I know, and I have been looking into it for a year now, there are no aftermarket supercharges or turbo kits that are readily available for the 3.0. I believe there was a guy on the 4x4 wire who custom installed a Turbo - but he is the ONLY one I know of.
My truck has over 200K miles now and is beginning to show the wear - leaky valve guides, rear main seals - so I thot as I would have it apart I would toss in some performance mods. Well, so far the HP per dollar value of the 3.0 upgrades do not really add up. Getting the heads done - exhaust - intake - plugs, wires, high energy ignition - really don't add up to much more HP. Even getting a custom built engine - $7K to $8K only gets you 200 HP total. I know I can build a couple chevy engines for that dough and really crank out the HP. Granted that does not really help out my 4runner - but I can do it - I think.
I have thot about doing the 3.4 swap - and I keep going back and forth - I cannot do it by myself, and $5k - $6K for someone else to do it - well, I am thinking I will just work in the 3.0 - remind myself that it has been CHEAP to run for the last 9 years and 200K miles - and stick with what I got for a while. :(
Sorry I am not much more help - but I have spent alot of time looking around and talking to people whom have tried a lot of things to tweak the 3.slow - and for some reason it just seems happy where it is. ;):
Aaron
No cheap performace mods, eh? Thats to bad.... Maaybe I'll buy an old 83 pickup and mess around with it. Do KN Filters add HP?
It really is too bad that there are not any good "bang for the buck" mods for this motor. It has been VERY reliable - and *seems* like it could be a good one to tweak - but I have found that it is not the case.
Before I did all the research I put in a K&N filtercharger - it did make the engine bay louder - and it did help with some low end touque - but to be honest - I should have just kept the stock air box and dropped in the K&N. It would have been cheaper, and kept it out of the wet elements better. It was not a really an impressive difference but it did make some.
I also got a chip for it - talk about a waste of money. Urgh. I wish I had found these forums before I spent that chunk of change. Did the chip make a difference - yes - was it worth the cash - NO WAY.
I did get the T-Body bored - and most likely headers and exhaust are on the way - despite the VERY mixed reviews about them. I have a hard time believing that it would not make some sort of positive dent in the performance. In practically every other automotive application breathing is where it is at.
I will soon have to pull the heads off to fix the valve guides - and it will be good to do the headgaskets - blah blah - I will then decide if I want to port them and the intake. I figure once I get to that expense a little more wont hurt. But I will wait as getting to the heads on this thing is not like taking them off the old '72 camaro. Geez - even trying to get to the leaky valve cover seals - I might as well take the heads off then, I have to remove the upper intake manifold - might as well go all the way.
If you do get the pickup - there are several great places that deal with the 22-r engines. Those have a huge following of people who mod them and there are some good, reasonably price mods too. http://www.engnbldr.com/ is probably one of the most knowledgable and respected people I have run into for 22-r series engines. He even has some opinions on the 3.slow.
That is just my opinion.
Aaron
Thanks a lot for the tips Sound Guy. I was thinking about replacing the filter with a K&N. Whats the average price range on those? Does KN make filters that fit stock parts? What is the positive result to having a bored T-body and does that cost a lot? (As you may notice by the $ questions I'm on a tight budget). Also if you could answer my question on mufflers in the 'millage' thread that'd be great. Thanks! -Dan
the K&N - I think about $40 for the drop in -
The T-body - $250 ish - it really is simply more air in. I have to say - they might have wound the spring a little tighter because throttle response is a little better. :p However I think the MAF really screws up the more air in theory - talk about a restriction....
Aaron
So the T-Body, is that something that can be done by the
"do-it-yourselfer" type of person? I'm thinking about doing that if it isn't to complicated...
-Dan
uh - no, I wouldn't say that the t-body is something you can do yourself - . Unless of course you have your own boring mill - and a basic knowledge of machining. Then you are in!! Then it is just finding the oversized valve and re-assembling it.
aaron
I guess 2 years of junior high woodshop doesn't count.... hehe. I'm still looking towards the drop in filter but I haven't made a final decision. I'm also looking at lockers and solid axles so I can go out and do serious off roading. Would you knowanything on solid axle swap and lockers?
SAS - well, apparetnly you can get some good lift using that instead of the IFS that the truck has now - but it is not a swap for the faint of heart.
http://www.4x4wire.com/forums/showf...81025&page=3&view=collapsed&sb=5&o=14&fpart=1
Lockers - well, it appears they are the way to go if you really want to get dirty. I guess there are two different lockers to use on your truck if you do not want to mod the rear diff. One is the toyota - and the other is uh - I forget - I think it is an ARB air locker- I think.
If you are very serious about doing these types of mods to your truck - I suggest joining the 4x4wire.com. These guys are serious and VERY good. Check out their archives - EVERYTHING we have talked about has been covered at least 10 times. So becareful what you ask before checking !! ;): Not that I don't want to be of help, but now you are heading to things that I know nothing about.
Aaron
Ok, I'll go ahead and check out 4x4Wire. I might do lockers, I might not. The solid axle swap I think I'll do on a pickup with a lift, once I own one...
Dan
I think that is a great idea.
Locker(s) would be great for good trails and decent mudding. I can go LOTS of places in my 4runner and I don't have lockers (yet) ;): There are some steep hills and such that it really bogs on - but that is mostly because of the Auto Tranny - but for general trails and such - it works really well stock. Get a good bummper (ARB or TJM with a winch) for protection and recovery, some lights - CB and a GPS and I think you will be suprised where this thing will go with very few mods. I have buried the hood underwater and blasted thru the other side with only a studder - and I have spun the tires dragging me sideways thru the mud for 70+ yards trying to get out of a rutt and succeeded. I have towed a 3600lb boat (not recommended) to the lake and back several times - and it keeps on ticking.
I love my 4runner - I really do. It has 204K miles on it - and I think I can make it another 200K if i care for it really well. I have decided that if I really want to toy with something I will get a jeep or a toyota truck. They have LOTS of parts, and are really easy to work on - cheaply. My 4runner will be for long winding trails and daily driving. As it is one of the most reliable vehicles I have ever owned. I live in Tennessee, and my truck has been to upstate NY(twice), Montana(4 times), South Florida(twice a year since I purchased it new), Chicago(twice a year since purchased it new), Arkansas, Northern Indiana countless times (my parents live there), Boston, North Carolina, Ohio - - the list goes on. I feel a couple more trips to Montana in my future and the the U.P. of Michigan.
With the truck, you will get an engine that is much more "mod-able" and a vehicle that is MUCH more suited to going seriously off road(lighter, shorter, better HP per dollar). Plus there are SO many parts out there - especially if you ding it up quite a bit - or hose your engine.
By the way - the 4x4wire plug was not a slight to this group - it is just much more active.
Aaron
Before you do consider a lift, SAS, or lockers, consider what type of offroading you plan to do. Not everything requires a solid axle, etc.
You can do a lot with a little if you know what you're doing.
I plan to do mild watered-down mudding thats only about 3 or 4 feet deep, some steep hills, and going fast on level dirt roads (I want to make a lot of dust). I'm also trying to talk my friend Devan into buying a used Toyota pickup/4Runner from the 80's but its not going well. Oh well..... anyone know where I can find a tube bumper for under $100?
a properly setup turbo system will produce more trq than NA motor. if i ever get my hands on a 1st gen runner, my setup will look similar to our prerunner :D
