Oil analysis will tell you what interval to use.
And about that dual by-pass Amsoil filter. Go to bitog.com and do some research. I've always wondered why Amsoil is the only company that sells a combination full flow/by-pass filter with that strange little valve. That valve actually adds resistance to the full flow filter so the by-pass can return it's oil to a lower pressure stream on the return. So between the oil pressure drop from that valve and any extra resistance do to normal crud build up in the full flow filter, your by-pass will start slow and gradually start working better as the system builds up some back pressure. Interesting!
