How Many Miles on your 4th Gen?
90,000 mi 2003 limited v6 everything stock except front caliper and all 4 brake disc.. about to replace the panasonic battery weak crack on 4 deg weather
My last trip over the holidays took me to 204K. Drove it to Northern Illinois from DFW area & back. We were going to take our car but when my Dad told me how the roads were, I told my wife lets load up the 4Runner!
Then after getting home we turned around and drove it to Louisiana to see more family. No problems what so ever.:lookout:
Bought my 03 new, have 72k miles now. Transfer case actuator leaks and speedometer is dead, using garmin gps for speed now.
Bought it with 102,000 and it now has 104,000. Did the timing belt, water pump plus all the fluids. Hoping for many more.
04 Sport V6 4wd with 168k. Only problems were a/c compressor, front calipers, and xreas. Just installed a hidden hitch receiver to accept the weight distribution hitch in order to pull a 23' travel trailer. Also, replacing the radiator and adding an additional transmission cooler for the hot temps here when towing.
I wouldn't be adding all of the extras if I didn't trust it could go at least another 100k or so pulling a 5000 lb trailer.
200k
I will hit 200K within days of this post. Absolutely rock solid. It has received a new rear wheel bearing and an interior bulb other than maintenance. Here's a pic of the dirty girl.
'03 Limited 4x4 with 54k miles. I just bought it from the original owner about two weeks ago. Only routine maintenance + new battery and tires (at least according to owner and Toyota Owners service history).
03 limited V8 with 109K.... Only issues so far are brakes (frozen calipers) and my driver side door lock actuator freezing up and having to be replaced.... Otherwise normal maintenance....
'03 with 212k miles on it now. Bought it in 07, and completely neglected it's maintenance compared to what it should've had done to it. That's changing now.
04+08
'04 190,000 miles, never had a problem, just oil and tire changes. Very fortunate
'08 62,000 miles (just purchased less than a week ago)
I just hit 260k miles on my 05 V6. Running PERFECT. Gave her a nice oil change and stopped her squeaking by replacing the serpentine belt also. Expecting to get at least another 100k miles on her.
utkrstam
