Hi all -
New to the forum (my first post). Please be gentle; it's my first time.
I have a '97 4WD Auto 6 Cyl w/the 5VZ-FE engine.
Noticed a loss of power when accelerating, and a significant "hesitation" when I'm coasting at 50mph and slowly start to add gas. I thought maybe it was tranny, 'cuz it sort of jerked (reminded me of when you're trying to pedal and change gears at the same time on a bicycle). If I punch the accelerator, it downshifts and does fine. When I get to about 3200 RPM, it starts to hesitate again.
I took it to two shops, both of which listed themselves as tranny specialists (along w/everything else). Not necessarily Toyota shops.
First guy says it's my Throttle Position Sensor. He said it *may* fix the problem. Says it "never opens or closes fully, and is really slow in transition." Wants $135 for that. Also recommends a tranny fluid flush (I agree) - $160 for that.
He also found the source of my radiator fluid leak = water pump. I'm also due for a timing belt. Wants $791 for pump, belt, tensioners, pulleys and bearings.
So, trying to be a good steward, I decide to get a 2nd opinion.
Yikes!
2nd guy says I need a tune-up. $525 for new plugs, wires and boots.
also says my catalytic converter is "coming apart - I found pieces of it in the exhaust" - $660 for that
He confirmed the water pump leak. His price for a water pump & belt is $589
He didn't say why, but quoted a fuel filter at $111
He found my dying battery (I knew this was coming, too) - $133
He also found my nasty tranny fluid - $162 for flush
So..... what do I want from you, sages of the best, and orginal SUV?
What do you think?
I got shop ramps, a creeper and the Chilton repair manual for Christmas. I have minimal skills but decent motivation - how much do you think I can/should tackle on my own? (I'm pretty sure I can do the battery - but what about the fuel filter? And getting to those plugs looks pretty tough).
Do you think I should fork over two grand and quit crying?
Sorry about the long post. I truly appreciate any insight you are willing to offer.
Yikes!
What do you think?
