until it gets warm enough inside the truck that i don;t freeze, go outside turn it over come in make some coffee and head back out 5-10 minutes during the winter, none during the summer.
~15 seconds when above freezing.
~1 minute when below.
Really, no time is necessary. Just start it, pull out and drive easy for the first few minutes...that's the best way to warm the engine and transmission.
If you are auto, then this is a bad idea because the tranny fluid drains out and takes a bit of time to recirculate to the important parts like the torque converter.
For me, I let it warm up until the engine reaches at least 1100 rpms.
On the coldest days it gets down to the upper 30's. After I start the engine how much time should I allow the engine to warm up?
does anyone know if idling for a long period is bad?
My truck is an auto, yes. And where do you suppose the 12+ quarts of ATF "drains out" to? The pan? Nope...that only holds a few quarts. The rest is actually in the TC, gear box, and a little more in the lines/cooler.
Fluid is what makes the transmission work. If your theory was true, I wouldn't be able to back the truck out of the garage until the transmission magically woke up from the engine running in park.![]()
Its good to see a fellow Houstonian, what part of town are you? I usually let it warm up for about a min when it is cold out.
