how the #^@*$ do you disconnect the climate control module?
Opi
im doing leds (attempting too even though i dont have enough bulbs) in my dash, i have everything apart and i cant figure out how to get the climate control unit out... theres like a million things plugged in and not enough space to pull it out to see the back. im going to light this whole truck on fire soon. :rockthrow:
yeah it gets kind acrazy in there
once you have everything unplugged fro your trim piece, pull your knobs off then the little cimate indicato plate should pop right off. thin you shoulld have 3 screws to the little white thing that is the HVAC controls. uncrew them, and then it should be free!
to get to the bulbs youll need to remove the little black box on the back of the white box by uncrewing 3 small screws youll need to unplug the the wires conneced to that too and then finally your in!!
i did all the unscrewing, the whole thing h as a bunch of cables and plugs holding it in, and it doesnt pull out the front of the dash so i can see the back?
ok so the one i pulled the bulb out the front and replaced it, i didnt have enough bulbs for both, nor do i even know if i used the right bulb for this one even though it lights up. now i have a hot spot of red and a nasty green one on the other side.
hmmm, once you on screw the 3 screws on the white HVAC it should just be held on by the plastic stabelizers. all you should have to do is push it in out of the holes and then pull it out.
but what about everything connected to the back? like the recirc switch has a cable, and the fan speed has a cable and theyre really tight. ill take picutres next time i attempt
sorry for the late reply i was on a long project lol! thats so weird, so it wount come out at all? there should be just enough slack to get it out and pull the plug on the back off.
post those pics when you get them thats just too weird
