I wanted to replace my blown factory sub and couldn't find any instructions to removing the panel covering the sub and amp. It was a lot of trial and error but I took some pics along the way to make it easy for whoever else wants to do this.
You're going to need a flat head and philips screw driver, 14mm or 9/16 socket and 10mm socket, torx screw driver OR 7/64 allen key.
Start by removing the cover and unbolting the rear right seat belt where it bolts to the floor using the 9/16 socket.
Now, using a flathead pop off the foot panel that is right there.
Take the philips head screw driver and unscrew the panel going across the very back of the cargo area.
Lift the panel to expose another screw that needs to be removed.
Unbolt the 10mm bolt in this little notch for the double decker cargo shelf.
Open the compartment to reveal another 10mm bolt to be removed.
pull back the carpet underneath the storage compartment to reveal 2 screws to take out.
remove star cargo net hook by pulling on the edge with your fingers, it will pop out.
Now start pulling from that same opening, but don't pull it all the way out.
