How to decode T4R VIN
chetJ
Hi Guys,
I wanted to know how to decode the VIN on 2010 and 2011 T4R's. For example, how would you decode
JTEBU5JR0B5045593
Any input would be great!
Hi Philsey,
I did search for the topic, but could not find the answer because some of the things for 2010 and 2011 have changed as far as VINs are concerned.
I guess my main question was
1) how to identify the year (does the B above in the 10th place mean that it is a 2011)?
2) How do we determine if it is a LTD, 4WD based on the 5-8 digits?
This might help:
The VIN (Vehicle Identication Number) is usually shown under the windshield. On vehicles made before 1989, an ID plate including the engine model, color code, trim code, axle code, and transmission code is on or next to the firewall (on vans, under the carpet below the front of the front passenger seat). On vehicles made in 1989 or later, an ID label with that information and the production date (but not the engine code!) is on the inside of the driver's door or on the lower part of the driver's door pillar.
Digit 1 - World Manufacturer Identification
1 = USA: NUMMI
2 = Canada: TMMC
4 = USA: TMM & NUMMI
J = Japan
Digit 2 - Manufacturor
T = Toyota
N = NUMMI
Digit 3 - Vehicle Type
2 = Passenger car
3 = Multipurpose passenger vehicle
4 = Truck
5 = Incomplete Vehicle
6 = Bus
?Digit 4 - Vehicle Description Section
?Digit 5 - Engine
A = 4A-FE
B = 7A-FE
T = 5S-FE
?Digit 6 - Series
?Digit 7 - Body Type or Passenger Restraint System
0 = ?
1 = Manual Belt
2 = Manual Belt w/ Airbag
?Digit 8 - Model
E = Corolla
T = Celica
Digit 9 - Check Digit
Digit 10 - Model Year
A = 1980
B = 1981
C = 1982
D = 1983
E = 1984
F = 1985
G = 1986
H = 1987
J = 1988
K = 1989
L = 1990
M = 1991
N = 1992
P = 1993
R = 1994
S = 1995
T = 1996
V = 1997
W = 1998
X = 1999
Y = 2000
1 = 2001
2 = 2002
etc....
Digit 11 - Plant
O = TMC - Supra plants
C = TMM - Ontario, Canada
Z = NUMMI - Fremont, California
U = TMMC - Gergetown, Kentucky
Digits 12-17 - Plant Production Sequence
Free OnLine VIN Decoder
VIN View /// AnalogX
I tried doing a quick search and failed but you might hit up google for a full description of the Toyota VIN code. I found one a few months back but I've lost track of it since.
Hi Guys,
JTEBU5JR0B5045593
Here's your VIN decoded ;
Model Year 2011 Make Toyota
Model 4Runner Trim Level Limited 4WD V6
Manufactured in JAPAN Body Style SPORT UTILITY 4-DR
Engine Type 4.0L V6 DOHC 24V Driveline four-wheel drive
Tank 23.00 gallon City MPG 17 miles/gallon
Highway MPG 22 miles/gallon Anti-Brake System 4-Wheel ABS
Steering Type R&P Front Brake Type Disc
Rear Brake Type Disc Turning Diameter 37.40 in.
Front Suspension Ind Rear Suspension Ind
Front Spring Type Coil Rear Spring Type Coil
Tires 245/60R20 Front Headroom 38.60 in.
Rear Headroom 38.60 in. Front Legroom 41.70 in.
Rear Legroom 32.90 in. Front Shoulder Room 57.80 in.
Rear Shoulder Room 57.80 in. Front Hip Room 56.50 in.
Rear Hip Room 55.70 in. Curb Weight 4805 lbs
Curb Weight lbs Overall Length 189.90 in.
Overall Width 75.80 in. Overall Height 71.50 in.
Wheelbase 109.80 in. Ground Clearance 9.60 in.
Track Front 63.20 in. Track Rear 63.20 in.
Cargo Length in. Width at Wheelwell in.
Width at Wall in. Depth in.
Standard Seating 5 Optional Seating 7
Passenger Volume 97.30 cu.ft. Cargo Volume 46.30 cu.ft.
Standard Towing 5000 lbs Maximum Towing 5000 lbs
Standard Payload 1495 lbs Maximum Payload 1495 lbs
Standard GVWR 6300 lbs Maximum GVWR 6300 lbs
Warranty Duration 36 month Warranty Distance 36,000 mile
Powertrain Warranty Duration 60 month Powertrain Warranty Distance 60,000 mile
Rust-duration 60 month Rust-distance Unlimited mile
MSRP $39,685 USD Dealer Invoice $36,111 USD
Destination Charge $810 USD Child Safety Door Locks Std.
Locking Pickup Truck Tailgate N/A Power Door Locks Std.
Vehicle Anti-Theft Std. 4WD/AWD Std.
ABS Brakes Std. Automatic Load-Leveling N/A
Electronic Brake Assistance Std. Limited Slip Differential Std.
Locking Differential Std. Traction Control Std.
Vehicle Stability Control System Std. Driver Airbag Std.
Front Side Airbag Std. Front Side Airbag with Head Protection N/A
Passenger Airbag Std. Side Head Curtain Airbag Std.
Second Row Side Airbag N/A Second Row Side Airbag with Head Protection N/A
Electronic Parking Aid Std. First Aid Kit Opt.
Trunk Anti-Trap Device N/A Keyless Entry Std.
Remote Ignition Opt. Air Conditioning Std.
Separate Driver/Front Passenger Climate Controls Std. Cruise Control Std.
Tachometer Std. Tilt Steering Std.
Tilt Steering Column Std. Heated Steering Wheel N/A
Leather Steering Wheel Std. Steering Wheel Mounted Controls Std.
Telescopic Steering Column Std. Adjustable Foot Pedals N/A
Genuine Wood Trim N/A Tire Pressure Monitor Std.
Trip Computer Std. AM/FM Radio Std.
Cassette Player N/A CD Player Std.
CD Changer Std. DVD Player N/A
Voice Activated Telephone N/A Navigation Aid Opt.
Second Row Sound Controls N/A Subwoofer Std.
Telematics System Std. Driver Multi-Adjustable Power Seat Std.
Front Cooled Seat N/A Front Heated Seat Std.
Front Power Lumbar Support Std. Front Power Memory Seat Std.
Front Split Bench Seat N/A Leather Seat Std.
Passenger Multi-Adjustable Power Seat Std. Second Row Folding Seat Std.
Second Row Heated Seat N/A Second Row Multi-Adjustable Power Seat N/A
Second Row Removable Seat N/A Third Row Removable Seat Opt.
Cargo Area Cover N/A Cargo Area Tiedowns N/A
Cargo Net Opt. Load Bearing Exterior Rack Opt.
Pickup Truck Bed Liner N/A Power Sunroof Std.
Removable Top N/A Manual Sunroof Std.
Automatic Headlights Std. Daytime Running Lights Std.
Fog Lights Std. High Intensity Discharge Headlights N/A
Pickup Truck Cargo Box Light N/A Running Boards N/A
Front Air Dam Std. Rear Spoiler Std.
Skid Plate Std. Splash Guards N/A
Wind Deflector for Convertibles N/A Power Sliding Side Van Door N/A
Power Trunk Lid N/A Alloy Wheels Std.
Chrome Wheels N/A Full Size Spare Tire Std.
Run Flat Tires N/A Steel Wheels N/A
Power Windows Std. Electrochromic Exterior Rearview Mirror N/A
Glass Rear Window on Convertible N/A Heated Exterior Mirror Std.
Electrochromic Interior Rearview Mirror Std. Power Adjustable Exterior Mirror Std.
Deep Tinted Glass Std. Interval Wipers Std.
Rain Sensing Wipers N/A Rear Window Defogger Std.
Rear Wiper Std. Sliding Rear Pickup Truck Window N/A
Tow Hitch Receiver Std. Towing Preparation Package Std.
2011 Toyota 4Runner Limited 4WD V6 Free VIN Search and Decoder - VIN Number JTEBU5JR0B5045593
Does anyone know why some VIN's come back with partial data and some come back with full data?
This one comes back with partial
JTEBU5JR9H5430417
This one comes back with full data
JTEBU5JR1H5435563
Weird.
Instead of decoding and list just his vin decode; can you teach us how to fish so all future folks that find this thread will not be reliant on you decoding their VIN???
