How to fender mod? 265/65r18 bfg
kaatahdin
Hello All,
After deciding on an Icon lift, my wife and I are trying for another kid, so.... I'm considering holding off on the lift, until I decide if we need 3rd row sequoia :noidea:
So, here's the question: 2009 V8 Limited with XREAS, how much fender lining / cutting to get some new 265/65r18 BFG KOs in there?
Thanks All!
Hello All,
Thanks All!
Are you running wheel spacers?
I have the 265/65/17 BFG KOs on my stock XREAS. It rubs a little on the passenger front. How much bigger are the 18s? An inch?
i am running 285/65/18 and i cut nothing, removed the front flappers but also moved the fender liner up a little. no cutting on the fender liner just trimmed the bottom corners of the bumper a little like this.
how the hell is this possible with 0mm offset? im running 15mm offset 1.25" wheel spacer and rub pretty bad even with mudflaps off and 265/75/16's
Hello All,
Thanks All!
I ran 265/70r17 (should be the same overall size as 265/65r18) Nitto Terras on stock, non-XREAS suspension for a few months with zero rubbing at all. Seeing the bigger tires fill the wheel wells really made me want a lift asap though...
Thanks for all the input guys, I'm not running spaces yet, I have heard that they can make it harder to stuff tires w/out lifts.
I do like the look though :)
