I bought a '94 SR5 4R, it has 33" tires, and a 4" suspension lift with air shocks in the rear. But the dog-legging is very noticeable, like 2" to the passenger side. HELP?
If it is the rear check your pan hard bar. This is the bar that goes accross the rear axle. It should sit about level in stock configeration ( in comperession to the ground). With the lift it will be a rather steep angle going from the frame to the axle, if they forgot to put the drop on it will dog leg usually to the passanger side. In some cases it will cause the rear axle to dog leg enough for the drive shaft to hit the gas tank.
