How to remove the aux input in the center console?
ubergeek
Hi,
I picked up 07 Limited today and I love it so far.
The only problem (owner did tell me) is that the aux input in the center console needs to be replaced. The previous owner broke off a tip of an input jack and got stuck there.
How do I remove that portion of the console? Do I need to remove the entire console? I am sure other members had the same problem given the location of the aux input.
Thanks in advance.
Pull up the trim around the shift column, it's held on by about 4 clips. You should be able to see the front of the storage compartment. Just unclip it a press it into the storage compartment and you should be able to unplug it from there.
charlesz
