How to remove window switches in a 4th gen
A/V1
Hey guys. Same as many of you, I'm trying to figure out a way to get illuminated auto switches on the driver's door. How do you remove the window switch panel in a 4th gen? It's a long piece, but I can't tell if it can be removed from the door without removing the entire door panel.
Thanks!
Brad
PITA. Be careful when you pop out that plate behind the interior door handle. Use a rubber screwdriver head, otherwise you'll scuff or scrape the hell out of the area.
A/V, Please let us know when and how you get the driver's door switches illuminated. There are several here who would like to do this mod. Good luck with this endeavor.
Thanks for the info & hints. I'll def take some pics on the way & pass on any info I come up with :zoom:
