How to replace door lock actuator
runnaz
Anyone have detailed instructions on how to replace the passenger door lock actuator on a 99 4runner? I have a new one ready to install but I cannot figure out how to get the old one out. I only see one mounting screw but after that I'm at a loss. Anybody done one that can help? Thanks.
ok once you pull the door pannel off you will see it on the lock it self inside of the door. after that you have remove all of the rods that go into it such as the lock and the handle also there will be 3 torque screws on the outside of the door to remove and there should aslo be a few 10 mm bolts that have to come out on the outside of the door then the hole door lock knob has to be removed and thoe hole lock and actuator should come out from the door and then you have to change it and reinstall i
tuṣṭāva
