how to replace fog light bulbs on '01?
ml37
anyone have instructions on how to do that?? i've searched a lot of forums but no one has info on it.
i'm doing a HID conversion but i'm not sure how to remove the oem bulb.
removal oem fog lights
you need a 8mm socket wid a rachet .. gotta go underneath the front of the car and unbolt the 8mm bolt .. den pull down the fog light assembly and disconnect the wire plug.. then on the back of the assembly unscrew the little phillip screws.. probably about 3 or 4 little ones .. there u would be able to take the bulb out..
the light bulb is H1 type bulbs.. hope that helps..
I just use a small phillips and unscrew the little screws and pull out the H3 fog bulb by undoing the little clip and just reinstall.
