How to replace the throttle cable?
97blkt4r
I'm sure this is an easy job, but can someone tell me what you need to do to take off and replace the throttle cable?
Also, if you were to by a throttle cable at a junk yard, how much money would you expect to pay for it? I believe new ones from the dealer are around $120.
The FSM is a big a$$ file, Im sure its in there somewhere. I will try and look a little later, got to work right now, it might be under the throtle body section.
I appreciate that. That's strange I don't see a throttle body section. What I see is subsection and I looked in all the ones it would make sense for the throttle body to be in.
Individual Chapters in PDF via google docs, requires Google login to download
* 01 - Introduction.pdf
* 02 - Maintenance.pdf
* 03 - Preparation.pdf
* 04 - Service Specifications.pdf
* 05 - Diagnostics.pdf
* 06 - Engine Mechanical.pdf
* 07 - Emission Control.pdf
* 08 - SFI.pdf
* 09 - Cooling.pdf
* 10 - Lubrication.pdf
* 11 - Ignition.pdf
* 12 - Starting.pdf
* 13 - Charging.pdf
* 14 - Automatic Transmission.pdf
* 15 - Transfer Case.pdf
* 16 - Propeller Shaft.pdf
* 17 - Suspension and Axle.pdf
* 18 - Brakes.pdf
* 19 - Steering.pdf
* 20 - Supplemental Restraint System.pdf
* 21 - Body Electrical.pdf
* 22 - Body Mechanical.pdf
* 23 - Air Conditioning.pdf
* 24 - Wiring Diagram.pdf
* Complete 4Runner Service Manual 1996-2002.pdf
