How To: Speaker Door Install
mountainman_gz
Hey,
I was wondering how I would go about installing a 6.5" speaker in the door of my '88 T4R.
There was no speaker there before and I want to put in a a bracket or something.
Wanting to know if someone has done the same and was successful
i put in some Boston rx57 speakers in my doors...i'll post some pics. basically just cut a hole in the lower part of the door and a spot in the panel. i noticed that when the bass would hit at certain frequencies something would "buzz" real bad so i re-taped that moisture barrier and zip tied the factory wiring harness nice and secure.
So the part that the speaker is attached to is the door right? See I didn't think that would be stable enough since the speakers in the front/back are actually mounted to a metal frame.
Pictures would help out
heres some pics, the camera died and didnt save the last one with the panel pulled away. i drill like a 3/32" bit and used 1" long drywall screws...worked great.
<br/>
<a href="http://s136.photobucket.com/albums/q175/easy_peezy/?action=view&current=IMGP0362.jpg" target="_blank"><img src="http://i136.photobucket.com/albums/q175/easy_peezy/IMGP0362.jpg" border="0" alt="Photobucket"></a>
<br/>
<a href="http://s136.photobucket.com/albums/q175/easy_peezy/?action=view&current=IMGP0364.jpg" target="_blank"><img src="http://i136.photobucket.com/albums/q175/easy_peezy/IMGP0364.jpg" border="0" alt="Photobucket"></a>
what about doors with pockets? I've got pockets in my 88, and so it doesn't look like there's any good spot on the panel (no flat areas big enough).
well i originally had installed a MTX component system (mid-ranges, tweets, and a EQ) the tweeters pop into this housing that has a metal clip. screws go though the housing to the clip and "sandwich" it tight to the panel.
i've never had a tweet fall out, but little mesh cover popped out when someone slammed the door.
Also....
i didnt have to drill into the door itself for the tweeters, that spot behind the panel has a access hole for the window motor, so it doesnt push up on the metal, just that vapor barrier...
well, in my '95 i don't have pockets, but i still built a box out 1/2" particle board for better midbass. covered it with matching carpeting and screwed it to the door. this way if i ever sell the truck i'll just remove the box and there'll be no trace of a speaker or a hole.
In your case, simply remove the pocket, install speaker, re-install pocket back. It'll sound just fine even with pocket covering part of it.
you can even install a 6x9 in the doors.
if you are going to build a box then first screwed it to the door from the inside through the speaker opening and then install the speaker.
