How to turn off traction control?!
Status
Not open for further replies.
Rnuttall
I have a 2007 4Runner SR5 4WD. When I want to be able to go mudding or off-roading, I would like to be able to turn traction control off so I can spin my tires in a mud hole or be able to fish tail on a trail. I have absolutely no idea how to turn off traction control and VSC when in 2WD. If there is a fuse I can take out and then put back in when I'm done mudding can someone tell me where that would be. Or, is there a mod I can do that will disable the traction control and I can deal with VSC. If anyone has any solution please let me know! The picture that is Attatched is the buttons I have in my truck. People say I should have a button next to these that has traction control on it but I don't have one in my car.
If you turn on the center locker it turns off traction control. But that may only be in 4wd. I have full time 4wd so I'm not sure will do any good in 2wd.
Yes this is only in 4H or 4L. I solved my issue tho. I needed to disconnect some cable from the master cylinder. It turns off traction control, VSC, VSC, trac, and ABS. But then the annoying part is it makes my dash say that I have my E-Brake on when I don't. Also this works in 2WD and 4WD. But honestly if I'm in 4WD I'm most likely going to be using difflock cause it is straight up ballsy and I will never get stuck in a mud hole when my differential is locked in 4WD. So thanks everyone for helping me out with this.
Status
charlesz
