I wired my amber halos and 10" LED strips to an OEM Toyota switch on the dash.
Get a 5-terminal relay and make these connections:
Terminal 85 - ground
Terminal 86
- If you want the halos to shut off with the parking lights or headlights on, tap the positive wire to either front corner light. It doesn't matter which corner light, whatever is easier for you to access.
- If you want the halos to stay on with the parking lights but shut off with the headlights on, tap the positive wire to either ballast. Like the corner lights, it doesn't matter what side.
Terminal 87a - halo positive
Terminal 30 - positive source that's "hot" with the ignition on, fuse the wire for safety
I've also come across something about tapping the wire that was cut to disable the factory DRL which is a grounding wire but since it's lower voltage, the halos wouldn't be full brightness. Does this sound correct and I need to use the relay method above?
Any luck figuring this out? I'm trying to figure out how to use my Halo's as DRL's also. Any help would be appreciated.Good question,it's probably a ground or full 12v, the low voltage stuff happens after that part circuit. I'd look it up right now but I'm heading to work so it'll have to wait until tomorrow morning.
I have a 2000 limited where I disabled the factory DRL and use the halos in full amber as my DRL but turn them off when my low beam HID retrofit's turn on, I modified a TRS wiring harness with 2 extra relays to do this, I'll search for the wiring diagram and post in tis thread when I find it.
Terminal 86
Thanks for the advice, planning to go this route. Just wondering what you do with terminal 87?
Nothing. That's the normally open terminal; 87a is the normally closed. Normally you use one or the other.
https://www.coolcatcorp.com/faqs/relays.html
What Durk said. I have the relay wired to cut power off.
