Hows The Stock Radio?
Hey man, thanks for the link, post #53 solved it for me. pretty newbie mistake (not knowing to remove the amp) but its figured out now. In case anyone else makes the same mistake I did here is the info:
http://www.toyota-4runner.org/838835-post52.html
Well FRACK!
Soldered up the Scion head unit last night. Followed Falcon115's instructions so there is no need to document that. http://www.toyota-4runner.org/audio-electronics/84630-t1814-installed.html
However, I go out to install it today and guess what..
Scion -
630324a0.jpg~original
Stock 4runner.
53acb9e6.jpg~original
Even better, i have two antena wires! :redbrick:
b3847185.jpg~original
I'm not sure what to do at this point.
My truck is a 1998 SR5
Follow that plug wire to a little silver box behind the radio - that's your old amp, probably! ;) Remove the amp and you will find the wires/plugs you need plugged into the back. The new radio has an internal amp.
Plug in your larger antenna wire and tape off the small one. Works fine.
peacefulpiranha
