Lug centric aftermarket wheels like the Pro comps pertains to the center bore/hole size which is 108mm in diameter- this is what you want for the 4runner as the wheels center hole is big enough to fit on the trucks hub.
Hub centric aftermarkets have a center bore size of 100mm which will only work on Chevy's, nissan's etc.....
Confirm this with the seller, though.
the same as the OE 5 spokes that came on my 00'. Lug centric wheels are balanced using the 6 lug holes as the center of the wheel while hub centric uses the hub hole to center the wheel. If you buy a hub centric wheel youll need lug centric spacers in order to balance it. If you buy lug centric wheels your fine.
285s on a non-lifted 3rd gen will rub like a fat woman in corduroy pants running a race to get a big slice of cheesecake.
And then wait until you try to TURN...
Whoa, now I am confused...
Are all hub centric after markets a 100mm bore? are all the "lug centric" aftermarkets designed to actually sit on the lip on our hubs?
My understanding is that all the 4runner OEM wheels are hub centric, not lug centric.
So what determines if it is hub or lug centric? Is it the hub itself? Or the wheel? Or both?
The wheel determines if it is lug or hub centric.
For those with aftermarket wheels, are we able to get hub centric rings for these trucks? I've searched and haven't come up with much.
Here you go. Ebay hub centric rings
Thanks for the link! Are the sized accurate though, our hub diameter is 108mm? I'll be measuring my wheels to make sure before ordering anything, I can't see them all being the same. That's a mighty thin ring!
