01PArunner
I'm looking at aftermarket wheels for my 01' 4-Runner. Should I get hub-centric or lug-centric wheels for my 3rd gen. rig? I'll be installing 16"x8" and 285-75-R16 tires. Will 4.5" backspacing be enough for no rubbing?
HUB CENTRIC. As far as back spacing goes I am not 100% but I believe the 4.5 back space is the way to go.
I have always thought that the 3rd gen T4rR has LUG CENTERED wheels untill
recently after I bought 17" Tundra wheels. I still have 1999 original rims. I measured the wheel bore diameter on both wheels and I've got the same number which is about 126mm. The hub diameter as measured was about the same 126mm that's why both original and Tundra wheels and the hub have a sliding fit meaning that we have a HUB centered design.
I am actually very surprised to learn about this because I have always been under the assumption that the 3rd generation has LUG centered wheels and you need a special (Haveka?) adapter for the proper balancing.
Can anyone comment on this, please?
The OEM lug nut has actually a "good" clearance fit inside the wheel stud hole meaning that there is no way the wheel has a LUG centered design.
My head is spinning...
It's an on going discussion.....decent info here...
"Lug Centric" Wheels, huh? - TTORA Forum
It will probably only make it less clear.....
I have come to the conclusion that the wheels are both hub and lug centric.....
Fits tight on hub and the lug holes are precision drilled....it will make your brain hurt.....![]()
this is half correct.
factory toyota steel wheels are both hub-centric and lug-centric.
alloys are hub-centric.
So, why the need for the lug centric Hawkea adapter for the balancing then?![]()
You're gonna drive yourself crazy trying to figure it out lol
Seriously. I have the factory alloys that seem lug centric from what you just described. That and the fact that my vibration issues disappeared completely after I had a lug centric balance![]()
The alloys should be hub-centric on the truck, but you have to balance them with the lug-centric adapter because the machine doesn't have a hub.
126mm? Are you sure? I thought the bore and hub are around 106mm. I keep gettng more confused the more I search.
