dirtbike250x
Would I use a hubcentric or lugcentric wheels on my 96 4runner?
Hub-centric. If you get lc it will vibrate. Kind of rims you thinking about getting.
ideally, both.
how would you get both it says the wheel is either hub centric or it is not, there is a why to have both kind on the same wheel?
well our factory alloy wheels are both hub-centric (meaning the wheel's center hole is machined to fit the hub exactly) AND lug-cetric (meaning the lug passes through the wheel and centers the wheel on the lug bolts).
If you are looking at aftermarket wheels it's more difficult to find a wheel that is both, in which case you'd want to get a hub-centric wheel over a lug-centric wheel.
our wheels are hub-centric only. It cant be both. I know what Liny is trying to say, but the lugs do not center the wheel on the hub.
Centering the lug hole around the stud has nothing to do with centering the wheel, our wheels are hub centric. And I'm not sure the lug nuts are beveled, but if they are it just centers the hole around the stud, but that does nothing to center the wheel, it just centers the hole. Again I know what you are trying to say, and i know I am being critical, but you would not use the term lug centric in this case. In the end, even if the lug nuts were not beveled and it did not center the lug hole on the stud, the wheel would still be centered on the hub, perfectly.![]()
This question came up with me when I ordered wheel spacers. I was told that the later models, like from the late 90's on are all "hub-centric". I am thinking that when I installed them, there is a lip around the hub that the spacers fit on snug, which is what centers the spacer, and wheel. The lugs, when tightened would not do anything to center it as it would not move. I would presume then, not assume, that the "lug-centric" wheel is flush, and when you tighten the lugs down, it allows slight movement of the wheel to bring it in to center.
