HVAC and the PCB light swap
Wile Kyote
I started the led conversion for the center console, switches, and cluster! Never noticed that the majority of the people skipped the indicator LEDs on the PCB. Curious if these are the same LEDs as used on the speedo cluster, and if it is one LED per selection option. I have not been successful yet in digging up information on these.
I was also curious if anyone has had success with 'capping' the bulbs. I read that using bulbs instead of LEDs allowed the light to spread better so I did the bulb route instead of buying aftermarket t3 and t4.2s. However, where the bulb sits is significantly brighter than the other areas. Curious if that is because these lack the condom covers over the OEM bulbs and if there is a solution.
I also think the hazard indicator bulb was missed, as well as I see no mention of the key barrel white ring (if these can even be done).
seltzernator
