gaslight
I had to replace the valve stem caps a while ago with the ugly black plastic kind. The valve stem caps would corrode and be a serious PIA to get off when checking air pressure. I ruined the originals trying to get then off with pliers.
I also found a long time ago that the wheels would get stuck to the rotors because of the corrosion. That was also a PIA to break them free when I wanted to rotate the tires. I tried something different this time by putting some Anti-sieze on the mating surface to see if that will make it easier to rotate the tires next time. I used just a tiny amount.
Anyone else have any problems with this stuff and do you have any better solutions?
I also hate that after the first year I started to see some of the clear coat coming off.
Aluminum rims suck.
Aluminum rims suck.
