I hate to even ask this Raptor light question but...
I have a 2019 4R SR5P. I want to install Raptor lights but do not want to buy the TRD Pro Grill or a facsimile. I see lights that say they will work and when I read the reviews, people say they won’t, then there seems to be a difference starting in 2020? I’m somewhat confused and only want to buy once.
So...what Raptor lights fit a 2019 4R SR5P?
So Eddie,
What lights (be specific) are you interested in installing?
Where and in what configuration are you interested in?
Any lights (to some degree & limitations) can be installed, they just have to be wired properly.....
I have some installed on my current and on my previous build....no issues!
So Eddie,
I want to install 4 lights in the top of grill with smoked lenses, I am still debating between white or amber but am leaning amber. I’m not worried about the install, I just want the diamond shaped lights that fit nicely in the grill.
These clearly state that they will work---I think. I can't vouch for the quality. Just something I stumbled across the other day.
4Runner Raptor Lights — Overland Depot
oops...didn't read clearly enough. It looks like for a non-TRD Pro grill they will not work in the configuration that you want. They say you have to put them on each side of the logo.
Hey Eddie, This is Wally. You haven't seen the Beaver around, have you?
[MENTION=315640]Eddie Haskell[/MENTION]
Ok!
The diamonds should be the same size on the SR5 and the TRD grill.
If so, you should be good.....
I'll look on my other build and see if they make 4 lights like my 3 light system on my TRD grill....
I'll get back.
EDIT:
Look here........EBay Front Bumper Grille Amber LED Light Black Lens For 4Runner SR5
and this.... 4pcs For 2014-2019 Toyota 4Runner Black Lens Amber LED Grille Marker Light Set
2020 has been a year filled with tragedies.
Ken Osmond, who played Eddie Haskell on Leave it to Beaver, died earlier this year at the age of 76.
Wow, I didn't even know that!....Loved that show, even though it was well before my time...
Ok!
I'll get back.
EDIT:
There in lies the problem...they should fit but will they?
Lots of should, ifs and maybes, I know someone has done Raptor lights without also buying the TRD grill...right?
You'd have to mount 2 on each side of the Toyota emblem, likely they would be mounted right next to each other to make it fit. I don't see why there would be an issue other than it not having the aesthetic "look" you're wanting. But that's a preference thing, not a technical issue.
Ok!
I'll get back.
EDIT:
From, what I remember, the grill diamonds are the same.
The grill that came on my 21 has a chrome horizontal bar running across it or otherwise I could measure it to check.
Yes people here have installed them on SR5's. I have seen threads here with photos.
The design that I sent you in the second link is the same as what I used. The outer part fits over, not inside the diamond. The retaining piece on the back also fits over the back of the diamonds. They went on flawlessly, you just center them up and tighten.
Hope this helps.
It was well before my time, too. I saw reruns of it in the 80’s.
Some Ken Osmond trivia - he was an LAPD officer after his acting career ended. He was a motorcycle cop.
Thanks for the link! I just bought the cheap Pro grill and it is time to upgrade my Raptor lights and get rid of the zip ties holding them on LOL
Alternate suggestion: Some 10" Baja Designs Light Bars behind the top grill.
They make a kit with everything you need.
The cool part is they have orange DLR built into the light bar.
And they use two 10" so that the Toyota logo on non-Pro models doesn't get in the way
https://www.toyota-4runner.org/3173450-post31.html
Plus you can light up the night with the light bars ...
thanks for this i like this way better than Raptor lights how much was the setup thanks
delislerebecca
