i have got lights, horn, 4ways, but nothing else!!!!
JLC84cam350
hey guys, i recently baught a 92 4runner, had a small side collision and i have replaced a thew broken parts, being the stabilizer shock, transversal bar i think its called (attaches to the stablizier shock), the passenger light and corner light, and the drivers side corner light. NOw i have got a big problem, i drove it home it went pretty good. IT did pull to one side, but i think i have fixed that with the parts i changed, but problem is i can't try it out cause i am not able to start it. I don't have any power that goes to the gauges or nothing. NOthing works when i turn on the key, yet the lights work, so do the 4way flashers and the horn. But thats about it, nothing else gets any juice from the battery. WHat did i do wrong??? I remember this, when i was putting on the head light, i think i must a hit some kind of wire cause it went pow, and a bit of smoke came out where the nut was (this is the whole cassing and everything that i replaced). COuld it be a blown relay or something, tell me what you guys think.
Have you checked all the fuses? there are 2 fuse boxes, one under the hood and one behind the drivers kick panel. The one under the hood also has some fuseable links.
Does the radio work? it's on the same fuse as the horn, so it should.
nope, radio don't work and i checked to see what wiers i had hit, one is small (red and blue line), and i notched the big one, bigest one in roll (white and green stripe i believe). I have no clue whats gone wrong, i checked all fuses and they are all good. I have power to the big one but none to the small, i checked with a volt meter.
Hey guys! i found the problem, broken relay switch, 80ohms one i think. Well my brother found that it wasn't working, saw a big gap in the relay, put a screw driver where the crack was and everything worked. He took it out for me but i would have rather done it my self, it was mounted a screwd up way lol. Had to take the whole fuse-relay box out to take it out. But only figured it out after we tore the relay too 100ds of pieces lol. At least i know whats the problem thanks anyway guys!!!
