I installed my bass system but one MAJOR problem..
gurman13o
So i was installing my wiring and my new system into my 2002 Toyota 4Runner and after everything was hooked up and running the Emergency airbags sign was on.. This did not happen before i had my system in.. what went wrong and how do i fix this?
wiring, wat did you wire up? new radio? when you ran the wiring to the amps-how did you go through the firewall? did you use something sharp that could have cut a wire under the steering colum?
I wired up a turn-on wire, power wire(through the firewall), RCA cables.. all through the side panels to the trunk. I went through the firewall by poking a hole in it using a Screw driver.
umm, my gears r turning. so many thing it could be. umm try un hooking the radio from the harness and see if it does it, just start going backwards from the install and see if its a crossed wire somewhere. maybe something that would help if someone on here has a pdf of the wiring of ur runner? figure out where each part of the airbag system runs in the car and check each spot?
