I know, I know...another tire question
anotherrunner83
I've dug around one and off for a couple of days now but can't seem to find an answer, maybe one of you have the same setup or know if it will work or not.
I have an 08 V8 Limited with the stock 18's. It's finally time for new tires and I'm wanted to go a size or two bigger. I have a 1" Daystar level kit and 1.25" Spidertraxx. I've seen a bunch of truck with 265/65 without a lift. I haven't seen any running 275/65s though. Does anyone know if they will fit my set up? I okay with moving wheel liners but not so hot on trimming. Any input would be appreciated. Thanks in advance.
dont have em myself, so sorry i cant give u a positive answer, but 275/65/18 come in at about 32.1 id say u will rub without at least 2in. lift u may be good with that small front lift if u move the inner fender liner way forward, & i doubt it but u may need trim or remove mudflap. the wheel spacers that may require u to slightly trim the lower fender. goodluck 18" wheel issues & tire size - do not read if tired of tire questions!! - Toyota 120 Platforms Forum http://www.toyota-4runner.org/4th-gen-t4rs/83007-275-65-18-all-terrains-tires-fit-stock.html http://www.toyota-4runner.org/perfo...ust-superchargers-more/78867-275-65-18-a.html http://www.toyota-4runner.org/perfo...ust-superchargers-more/33065-275-65-18-a.html http://www.toyota-4runner.org/4th-gen-t4rs/45274-tires-06-limited-18-inch-wheels.html#post376918
thanks guys. the 1" daystar leveler provides right around 2 inches of lift. I think i ended up with about 1 7/8". I can adjust the sensors or the rear air to give a little more height there. looks like this is the direction i'm going to go in, we'll see what happens. looks like the spare will, snugly, fit in the spare spot too. The 275/65 size opens up a lot more options than the 265/65 size.
