I searched the other night and then again but cannot find what I am looking for. I wouldn't have posted if I didn't search first. It's probably right under my nose but I just don't see it.I won't make the typical remark here , but if you check the maint. thread I believe you'll find the info there !
I typed in "compatible". Thank you. It looks like I want 90915-YZZD3 or even better if I can find part ending with 20004. I am hoping I am reading this right.
I believe someone actually cut the two filters open and notice a difference in filtering material and slightly different baffle/mesh cage construction. I forgot where I saw the thread.
interesting i will start looking for it and post it if I find it.
whats your take BlackWorks? I have seen the fram filter cut open and srsly will not be buying any more of those but from what I remember the Toyota OEM he cut open was just as good as the premium brands.
As a tech have you seen ANY issues with oil filters and Toyota's... are toy's more picky about which you use (IE. flow and pressure issues.)
thanks guy!
So whats the verdict here, does it even matter since they are all Toyota branded? how much better could the "supra" filter be compared to standard OEM if you change your oil regularly??
I feel like a little better flow can be expected but I doubt that it will be a big difference.
