I need Help!!!
traxxi2003
I need Help A340E output shaft bushing?
:crybaby:I need to know if on the tail housing of the A340E (1996-02 4Runner 2WD) transmission, Is there a bushing or bearing behind the trans output shaft oil seal that can be replaced? I have some play on the driveshaft slip yoke when moved up & down.
you will probably get better help if you help yourself and edit the title of your thread to something a little more descriptive. :)
DJNutshell
