4runnerTiger
So for the last week what I assume was my IAC was acting up.
The symptom was running fine but when I parked and went into park the engine would idle very high, around 2K when warm. Upon initially starting when cold it would idle around 1K, before this problem when warm when in park would idle at around 7-800rpm.
Yesterday after a 20 min drive, i moved the car a very short distance, and shut the car back off, when i went to restart it, it woul dcrank but wouldnt turn over. Eventually, it did start and got home.
This morning I cleaned the MAF, the throttle, and the IAC. Now it will crank and try to start but will not actually start. I have double checked all my connections, and everything is plugged back in. It has been sitting about 2 hours since i finished with the battery disconnected and it still is displaying the same condition.
Can anyone give me a direction to go? Would left over MAF cleaner or Carb cleaner in the throttle and IAC do this? Anything I should disconnect to let it air out?
Thanks in advance!
Thanks in advance!
