ICON 2.5 CDEV Series | 5th Gen 4Runner
ICON Vehicle Dynamics is extremely proud to introduce
the all-new Compression Damping Electronic Valve (CDEV)
powered by ICON Intelligent Control (IIC).
The combination of IIC and CDEV allow for automatic,
instantaneous adjustments to the shocks’ damping to
provide the absolute best setting for any given situation.
ICON Vehicle Dynamics 2.5” coilovers w/ CDCV are an
incredible upgrade for the front end of the 5th Gen 4runner.
ICON’s Vehicle-specific valving provides a sport tuned feel
on and off-road while offering 0-3.5” of lift height
adjustability for use of larger, more aggressive wheel and
tire combinations.
ICON's larger 2.5” shock body and increased piston area
over stock components provides improved damping ability
and outstanding ride characteristics across varying types of
terrain.
Remote reservoirs ensure optimum performance by
increasing the duration of consistent damping regardless of
situation, keeping the shocks at a cooler operating
temperature during heavy use.
The ICON CDE Valve upgrade is included for those desiring
an easy way to tune the ride electronically from inside the vehicle.
Compression Damping Electronic Valve (CDEV) is an
electronically controlled valve that meters the flow of oil to
regulate the amount of damping force that is created by the
shock when compressed.
_
ICON 2.5 Coilovers, Extended Travel, w/Reservoir, w/CDEV
Part #58747E
MSRP: $2,729.95
FEATURES & BENEFITS
- ICON's CDE Valve technology allows for in vehicle adjustment of compression damping settings and active adjustment via the ICON Intelligent Control (IIC)
- Increased wheel travel and ride quality over stock
- Vehicle specific tuned for superior shock damping and control
- Adjustable for 0-3.5" of lift height over stock
- ICON engineered Eibach Springs
- External reservoirs to attain cooler operating temperatures during extended off-road use
- 6061 Aircraft grade aluminum CNC machined components
- Corrosion resistant CAD plated shock bodies with 7/8" induction hardened, chrome plated shafts
- FK rod end bearings for extended longevity and minimal deflection
- Bolt-on kit - no cutting or welding necessary for installation
- 100% Rebuildable
- 100% Revalveable
TECH INFO
- OEM Wheels & Tires Fitment: Yes
- Recommended Aftermarket Wheels: ICON Alloys | 17x8.5 with 4.75” Backspace / 0mm Offset
- Recommended Aftermarket Wheels: ICON Alloys | 18x9 with 5.00” Backspace / 0mm Offset
- Recommended Aftermarket Wheels: ICON Alloys | 20x9 with 5.00” Backspace / 0mm Offset
- Recommended Aftermarket Tires: 33" x 11.50" (Larger tires may fit but fender trimming and modifications will be required.)
- TECH NOTE: Aftermarket front upper control arms required for installation
- TECH NOTE: Also requires installation of IIC kit (Part # 53504) and CDEV rear shocks (Part # 57810EP)
_
ICON 2.5 Shocks, 1-3", w/Reservoir, w/CDEV, Pair
Part #57810EP
MSRP: $1,994.95
FEATURES & BENEFITS
- ICON's CDE Valve technology allows for in vehicle adjustment of compression damping settings and active adjustment via the ICON intelligent Control (IIC)
- ICON’s internal “Bump Zone” increases damping by 20% to provide more control as the shock approaches full compression
- One-piece, hard anodized, impact extruded aluminum cylinders offer excellent corrosion resistance and consistent finish
- Remote reservoir design improves heat dissipation to reduce shock fade during prolonged use
- Premium grade 5WT shock oil for consistent suspension damping along a wide temperature range
- Nitrogen charged monotube design with piggyback reservoir
- One-piece digressive piston design with vehicle specific valving for unsurpassed performance and ride quality on and off-road
- 7/8” diameter induction hardened, chrome plated shock shaft
- PTFE lined spherical bearings and application specific mounting hardware
- 6061 aircraft grade aluminum CNC machined components
- 100% Rebuildable
- 100% Revalveable
TECH INFO
- TECH NOTE: Also requires installation of IIC kit (Part # 53504) and CDEV front coilovers (Part # 58747E)
ICON 5th Gen 4RUNNER IIC INSTALL KIT
Part #53504
MSRP: $499.95
ICON Intelligent Control (IIC) is the computer that monitors, analyzes,
and processes data in real-time. Information from the onboard G-force
sensor and Gyroscope perform calculations based on algorithms and
user-defined settings to predict terrain and wheel position.
IIC has the capability to collect information at over 1000 times per second,
process the data and make adjustments, then deliver those changes to
Compression Damping Electronic Valve (CDEV) in the shock absorbers in
under 40 milliseconds.
IIC also works as a data driver to connect the user to ICON’s proprietary
mobile App interface for monitoring and adjusting shock settings.
The IIC is mounted to the 2010-Up 4Runner using application specific
mounting brackets, hardware and wire harnesses, ensuring an easy and
clean looking install.
FEATURES & BENEFITS
- Offers selectable active shock damping adjustment as well as manual adjustment of baseline settings without exiting vehicle
- Onboard sensors monitor G-forces and movement of vehicle chassis
- Performs calculations based on sensor inputs, custom algorithms, and user defined settings at a rate of over 1000 times per second
- Sends necessary damping adjustments to CDEV shocks that react in under 40 milliseconds
- User interface provided by IIC Mobile App via Bluetooth connection to iOS device
- Mobile app offers preconfigured “Drive Modes” as well as the ability to create custom presets
- Also functions as a data logger for time, speed, distance, and G-force allowing you to record data from your trips
- Application specific mounting brackets, hardware and wire harnesses
TECH INFO
- TECH NOTE: Also requires installation of CDEV front coilovers (Part # 58747E) and CDEV rear shocks (Part # 57810EP)
_
Seeing how the 4th gen(and gx460)is so close.. when will they offer it?
And are they currently looking into this being a possible replacement to the AHC on the LX470?
Part #53504
MSRP: $499.95
FEATURES & BENEFITS
TECH INFO
_
Sorry for the delay replying to this question.
Several of us had a chance to speak with ICON about applications.
As of right now, the CDEV Series will be limited to 4Runner (5th Gen) and Tacoma (3rd Gen). Not sure on eta for 4th Gen.
There are no plans for the GX470 or GX460.
_
Do you have to run a complete system(all 4x shocks)?
Could someone wanting to transition be able to get the fronts and controller? Would there be any issue with tatt shocks not connected to the system?
_
seltzernator
